Bad Jump causing issues
macky
AAA came out and did a jump and must have done it backwards, after that the car turned on but the AC didnt blow cold air, inside lights / radio wouldnt work. Keyless fob also didnt work.
I tracked it down to the room fuse, i tried replacing literally 5 different fuses and every single one blew as soon as i put it in or connected the negative.
Anyone tell me where i should look. Nothing is plugged into the car, nothing in the cigg adapters either everything is oem
