So about a year ago, had some light vibrating/noise, was a front engine mount issue, replaced for like $300.
Suddenly, car went from just fine to vibrating badly, much worse than last time. Like I could tell the second 'it' happened. Thought it may have been an oil change issue, they say its either something, or the engine mount, so im pretty sure its engine mount again.
Its really bad with the car stopped in drive with foot on the brake, though theres a slight vibration even at high speeds and neutral.
I know there are 3 engine mounts, I think I can identify one, cant find the others. Is this something I could fix on my own or something, maybe its just a loose bolt or something? How can I confirm the issue, and can I fix it myself? If not, how much should the repair cost?
thanks.
thanks.
