Bad body control module (BCM) symptoms?
mts3
08 CX-9 GT AWD, 04 Audi A4
I've got a 2008 CX-9 with 59876 miles on it. Friday morning the wife started it and the following warning lights came on:
BRAKE
OIL PRESSURE
SKID CONTROL
TCS OFF
BSM OFF (FLASHING)
Also the turn signal indicators on the cluster don't work, although the actual external turn signals work.
I am thinking bad BCM but am not sure because everything on the car seems to be working (except what is illuminated on dash).
I have been going down the BCM inspections with a voltmeter as outlined in the FSM. So far all the inputs on the first connector are all good - oil pressure switch, reverse light switch, hood latch, etc. I hate to throw such an expensive part at the car if it isn't bad. It's out of warranty and the nearest dealer is 2+ hours away! Any thoughts?
Tyson
