Hi,
I am not technically advanced, but wondering instead of pulling a wire from backup camera through the hatch into the cargo light area to connect this to the power source, If I had a backup camera with a transmitter, can I just mount the transmitter inside the hatch behind the licence plate and splice into the reverse light wire located in the hatch tailgate? This way I do not need to pull wire all the way through. Does this work?
I have Base model 2013 cx-5. what colored wire should I splice into? Is there any way to avoid splicing into existing wire?
Anyone can help will be great.
Thank you
Thank you
