Back to stock wheels, what do I need
ms6DiGi
Contributor
Mazdaspeed6
I'm planning on taking my Varrstoen wheels off my car this week and going back to stock wheels. I have open ended lugs that are a different size so I'm assuming the wheel bolts are a different size also than the stock were. What do I need to buy and what size? Bolts and nuts? And where can I get them? Thanks
... I don't even remember what stock lugs look like ... ha. I don't see why regular open lugs won't work with stock wheels though. The lug holes are rather large, iirc.
OK, I feel like I remember when I got my wheel spacers put in the guy said he had to cut the studs for some reason. But I guess if I'm using the spacers again it should be fine. I am gonna bring my car to a tire shop tomorrow and find out what the actual deal is. thanks
I think I have a full set of stock lugs laying around somewhere, let me know if you want or need them. For the free.
If you plan on reusing the spacers, you should be fine. If you want to remove the spacers, you'll need to have new studs pressed in.
In that case, you can either get stock studs and use the acorn style lug nuts, or longer ARP studs (I don't know the part number - they're for a GM application), for open-ended lug nuts.
