If you figure out how to remove the front Bronzeoil's I'm listening. Everything is so tight I can't get that bolt out.
Action Jackson said:If you figure out how to remove the front Bronzeoil's I'm listening. Everything is so tight I can't get that bolt out.
pigeon said:Did it explicitly say not to lubricate the shifters pivot point?
Try loosening the bolt on the bottom of the shifter, and retorquing it to spec.
livetoride said:Do the other bushings actually make the shift smoother as well as removing play? I love how short the b&m is in my car but it is not nearly as smooth as the other ones i have felt in some of my friends car. The clicking sound going from each gear is awsome,but its so stiff. I know it said not to lube the ball on the shifter, but has anyone else greased it up to try to smooth it out?
