mspeedP5
Contributor
- '02 Protege5
tallrd said:I'm doing that exact same thing, and after researching I hope I've revealed some good info which helps more than just me. That said, I'd like some second opinions to be 100% certain.
I can say with 90% certainty that you can unscrew the stock unit, remote locate both senders using 1 braided stainless steel line with a "T" fitting at the end (stock on one side, AutoMeter on the other), and all while maintaining your turbo line in the stock spot. I've attached a photo for review (bottom-side pointing up) to make sure we are all talking apples and apples. Red arrows indicate what I've come to believe is the stock unit and green arrows indicate where it would unscrew from (I unplugged the small green wire which was leading to it just for the purpose of clarity, otherwise that would still be connected).
If I'm correct, you can use a male to male fitting from that newly freed up spot off the block to go into the braided line. Although I didn't remove the stock piece to check, I did closely compare an 1/8" NPT threaded adapter to it and it looks identical. Therefore, that's what the stock port utilizes. So, with the necessary adapters, I'm fairly certain this can be done with no negative affects.
Thoughts?
The info I have is that the OEM sender is 1/8" BSPT so you need an adapter to go from 1/8" NPT to BSPT.
Autometer has one. Part No. 2269 Metric Adapter.
So what you plan to do is put a tee at the OEM port. One side will be the feed to the turbo, the other side will feed a line to another tee that will supply the OEM sender plus the new gauge sender. Correct? This would then require 2 of the above mentioned adapters, or something similar to accept the OEM sender.
