kulkarnipb
- 2012, CX-9 Touring
I received request to share sources to buy tools/oils for each of the videos I created . So I am sharing all the details. Hope this helps for the DIY projects. These tools/oils are for reference and information only !
*************** ATF Change *******************
Thanks cpb406 and 'Pootie Tang' for showing ways on drain and flush on the below threads respectively -
http://www.mazdas247.com/forum/show...luid-Changes&p=6326764&highlight=#post6326764
and
http://www.mazdas247.com/forum/showthread.php?123855296-Home-transmission-flush-success
Video -
3/8 ratchet
http://www.homedepot.com/s/3%2F8%20ratchet?NCNI-5
OR
https://www.amazon.com/dp/ (commissions earned)
1/2 ratchet
http://www.homedepot.com/p/Husky-10...tchet-H10012RAT/206034100?keyword=1/2+ratchet
OR
ATF
( at least 7 bottles of 1 quart each )
OR
17 mm bit hex socket
T-40
http://www.homedepot.com/p/Husky-T55-Torx-3-8-in-Drive-Bit-Socket-H3DHBST55/202940696
If you don't have dip stick for ATF ( if I am not wrong CX-9 - 2011 and onwards ) , then below tools are needed too -
3/8 - 18 inch extension
T-55
http://www.homedepot.com/p/Husky-T40-Torx-3-8-in-Drive-Bit-Socket-H3DHBST40/202913547
Oil Pan and funnel -
Buy from dollar tree or any dollar shop or any other shop
Vinyl Tube to attach to funnel and attach clamps ( if you find these in a dolalr shop then awesome, otherwise goto homedepot ) -
http://www.homedepot.com/p/Sioux-Ch...-D-x-2-ft-Clear-Vinyl-Tubing-HSVSP2/204407884
http://www.homedepot.com/p/Everbilt-1-3-4-in-Stainless-Steel-Clamp-6720595/202309386
************ Rear Differential Fluid change ************
Video -
Oil
( 2 bottles since required quantity is 1.1 quart )
Oil Pump
OR
http://www.walmart.com/ip/Gas-Oil-Siphon-Pump/39105532
OR
OR
http://www.homedepot.com/p/Arnold-Siphon-Pump-Kit-490-850-0008/203051321
Oil Pan -
1/2 ratchet
OR
24 mm socket
************ Transfer Case Fluid change ************
Thanks to avidien for creating original thread with lot of information at - http://www.mazdas247.com/forum/show...Changing-CX-9-transfer-case-gear-oil-(photos)
Video -
3/8 ratchet
OR
Oil -
http://shop.advanceautoparts.com/p/...01/7070083-P?searchTerm=royal+purple+gear+oil
OR
OR
http://shop.advanceautoparts.com/p/...t.-102490-98fs32/7070076-P?searchTerm=75w-140
Suction Transfer Pump and since Pump's power card don't reach to car's battery easily , use jumper cable as extension( if you don't have already , buy it)
Oil pump -
OR
OR
and
Video -
3/8 ratchet
OR
1/2 ratchet
OR
ATF
OR
T-40
T-55
Video -
Oil
Oil Pump
OR
OR
OR
Oil Pan -
1/2 ratchet
OR
24 mm socket
Video -
3/8 ratchet
OR
Oil -
OR
OR
Oil pump -
OR
OR
