- 2017 CX-5 GT AWD
One of us need to get a big 3d printer.![]()
I was thinking that too....
@lowincash,
It fit where the sliding removable tray was? Would it work if you had a charger plugged in?
Short USB extension cables [3" or 6"] can solve some of those problems.
who's the next to try? https://www.ebay.com/i/263538291414?chn=ps
Wished seller had some pictures with tray installed on console. At least the front hole for ports access seems well thought, hopefully tray either sits on rails, or is narrower than them so can easily drop in place and be removed.
if someone ends buying this one, would appreciate fitment report.
I got the amazon one today, it fits perfectly fine and didn't hit the usb drives that I have connected and there's a hole for the cable to come through.
https://c1.staticflickr.com/1/811/40921843312_81a462cf4b_b.jpg![]()
The one I ordered from ebay finally came in and it fits perfectly fine, I didn't need to do any modifications to it.
@lowincash, great to hear, appreciate sharing. A few questions if you don't mind:
A) Country, trim & year of your CX5? USA Touring'17?
B) How easy is to remove the insert? Just grab by side tabs and slides out?
C) Can you still use the little tray that comes standard with the CX5?
D) Mind sharing the eBay link?
Thanks,
Thanks,
The link for the eBay one is on the first post by the OP. I have a 2017 GT. You can't use the little tray anymore on the eBay one but you can with the amazon one. Are you talking about the red inserts that it came with? They just come right out, it's not stuck to anything.
I have the same box as the one in the picture, I can answer your questions:
A) USA, 2018 Grand Touring
B) Very easy to remove: Just pull it up
C) Yes you can use the OEM tray, it fits under this box. You end up with three levels if you use it: The bottom of the enclosure, the OEM tray and then this one.
D) https://www.ebay.com/itm/152937437557 The picture on the ebay listing is not accurate, it looks like the picture on this thread.
Yes, thank you.
I just ordered the eBay one as well.
Thanks for answers and pics. Just ordered, now to wait 2-4 weeks.
Yes, thank you.
Just got the console storage box from eBay seller. Perfect fit, I just made front USB port a tad wider so the iPod shuffle could fully insert. Was even able to keep the small standard tray in place, sitting on top of new box.
