Are these Vapor canister purge valves the same..?
I have to ask this, too: is your solenoid actually bad? Blow through it with your mouth, see if it passes air. Now apply 12v and blow through it again.
Is it wide open one way, and *completely* sealed the other? If so, the solenoid is good, and doesn't need to be replaced. Your leak will be somewhere else.
Good qustion. Never put current through it to check. Did clean it out and have been hearing clicking and I dont think its coming from the valve train so I was thinking it was the Purge Valve.
Thanks for that tip tho, deff will try and get back.
