A'pexi turbo timer
i have mine installed, it was kinda a pain, but really easy. PM me and ill give you my number, then call me sometime 2morrow and ill tell you what wires to splice into.
Thank you so much that is a huge help ..But i still need to know what wires from the turbo timer go to the three wires you pointed out i'm using a Apexi turbo timer and the instructions say that one (Red) is 12v constant , (Blue) is Ig2 out put , and (Green) is Ig1 out put.... Where do those three wires go RED = constant 12 ,BLUE = Ignition Start 12V , BLACK/WHITE = Accessory 12V If you could clear this up it would help me so much Thanxs Angela
Orange look at the first link, the blitz turbo timer is exactly the same and shows where all the hook ups are.
ya the blitz TT install is basically the same, but since i have an apex TT installed i can just tell you that the wires, this is if you had the wiring harness pointed away from you and you are looking at the wires. are red from TT = Top left Red, Green from TT = Top Blue wire , Blue from TT = black/white
also if you dont hook up the a/f you wont be able to use the automatic mode (battle mode, what ever you want to call it) i think its like pin 68 (pink wire) for the positive side, and pin 7? something for the ground its a black ground wire. do a search for the wire diagrams and check out linux racers thread in the how to section on hooking up the a/f
