I've read (and keep in my pc) lots of information and diagrams about the Renesis' design, engineering highlights, etc.
Due to not having a peripheral exhaust port, the apex seals stay lubricated longer. Also, there are 2 oil injectors pointed to the sides instead of older 13B's one in the center; this allows more even spread of oil film. Since the oil film spread is better it allows to use less oil compared to a center injector which required more oil to evenly reach the apex seal's corners.
The OMP is the best design yet, as you said, varying by rpm and load and having higher flow. The higher flow is required because of 4 injectors instead of 2 and significantly higher rpm limit (my FD fuel cuts just shy of 8000 rpm).
Also, less oil is needed just because it's N/A, which creates less stress on the engine. Note that Racing Beat recommends a modification of the OMP to increase flow if you are using forced induction.
Now, I'm talking about what it was designed for, it doesn't necesarily mean that it actually works that way in real life conditions. Remember there have been numerous PCM calibration flashes, and they may have increased the flow. Just as an example, the Renesis was first designed to output 280 ps (276hp) at near 10k rpm with dual throttles (RX-Evolv) then it was lowered to 247hp (still true in Japan) and finally, taking into consideration the new SAE standards it is sold as having 232 hp.
The same could hava happened to oil injection, it may have been designed to use less but it could have been recalibrated for more after been out in the streets and Mazda gathered more data, etc etc...
KYLiquid said:
since i posted the above, my consumption has slowed down, its back to about 1qt per oil change.
Anyway, i read the opposite of what you said, the renesis injects MORE oil than any other rotary as mazda felt that previous rotarys might not have been getting as much lubrication to the seals as they thought it should. In turn the OMP (oil metering pump) in the RX8 injects MORE oil and FLOWS more oil than any previous OMP. Also the RX8 varies the OMP much more than any other rotary car based on RPM AND LOAD. That along with the Higher redline (9600 RPM Fuel CUT) the car uses more oil when driven hard, but less when at idle.
Either way, I dont mind filling up the oil everytime I get gas, it takes what, 60 secs of my time.
