AP not reading AFR or LFT?
LOL WUT
While logging with my new AP every time I load the data to the computer it is saying my AFR is 14.85 from start to finish and it doesn't move one bit. Just wondering if anyone may know why the AFR could be logging incorrectly. The same goes for my LFT's.
BUMP. I have tried everything to get this to work and my AP still says my AFR is 14.85 and never changing, from idle to redline it just says 14.85. And my LFT stays at 0 no matter what also. Anyone have any idea what may be causing this?
Have you updated your AccessPORT? Are you getting any CELs for your O2 sensor? This behavior could suggest that you have a faulty wideband sensor. If you unplug the sensor do you see any changes in the way the AP reads?
The accessport is updated. I am getting a CEL for my first 02 sensor p0134 and another p0031. I disconnected the sensor and there was still no change.
If your sensor is unplugged how can the AP read it?
What I mean is that I tried disconnecting the sensor to see if it made a difference and there was none. The car makes no changes with it plugged in or unplugged. Cobb told me to see if the car made any changes, if it didn't I more than likely had a faulty 02 sensor. I plugged it right back in.
