Anything we can do to get more traction?
MrDiggler said:
I don't know about you all, but my MSP pitches noticeably front to rear when I romp it (or rear to front when I slam the brakes). Obviously, the pitching indicates a quick weight transfer. I'm agreeing with the others that it's a spring issue, but it could also be an issue with the struts. I'm not exactly a suspension expert. I do know that it seems to be about the moment I get the weight transfer off the front end that the tires go up in smoke. I'll be putting stiffer springs in down the road. Gonna get some mileage out of these first.
Anyone else notice this weight transfer happening? The chassis setup seems plenty stiff side to side, but it may not be enough front to back for good fwd traction.
Theyres definately weight transfer.
These springs are only about 25% stiffer than stock, and only .8in lower.
I believe tein s techs are 47% stiffer than stock, and still retain a fairly comfy ride.
Id look into those. :)
