Anyonr having a problem with Nav not switching day/night mode?
kcshaner
2007 CX-7 GT
On user settings you can select auto where at night the nav background is black, and during the day its a light background. Well, mine does not switch from day to night mode when its on auto, I have to manually go in there and change it each time...its quite annoying.
Has this happened to anyone else? Have you had it fixed?
One thing to check:
On the left-side of the instrument cluster is the dash illumination dimmer - opposite the trip odometer.
It adjusts the intensity of the dash lights - BUT... if you PUSH it in, it toggles between the normal dash lighting and a "bright" setting which will leave the NAV (and the dash) bright even under night conditions set to auto.
Check that first.
CX7_Scott said:
One thing to check:
Check that first.
Will do...thanks!
