well i would like to keep the fuel economy and give the engine some protection with the zinc. sometimes i do like to push the car when its hot so that will give me some assurance that it wont wear faster because of that.The question is, why not just run 10W30 like the manual suggests. You're seriously making this harder than it should be. Why don't you think 10W30 will be fine for you?
And you don't think a 40W is going to hurt fuel economy? It's thicker which means more resistance which means you're going to have worse fuel economy. I don't know anything about zinc in oil but my guess is it does little to nothing in the long run. If you're worried, go with some pricey synthetic 10W30 like Redline or Amsoil (be prepared to pay nearly $10/qt) but for me regular Mobil1 synthetic has worked just fine over the years. I'm just saying, you're not going to see any miraculous improvement with a certain type of oil.well i would like to keep the fuel economy and give the engine some protection with the zinc. sometimes i do like to push the car when its hot so that will give me some assurance that it wont wear faster because of that.
but isn't my engine a bit worn out now? that's why i was thinking about the 5w-40. on a new engine it would really be unnecessary but since my engine is older now its time to up the grade to protect it like it was new and fill in the gaps that the wear caused. i been using 5-30 mobil 1 since my first oil change so because its got 82k miles on it i was thinking to give it similar protection like it was new.
