4 second 0 - 60 doesn't sound as impressive when my 4500lb 7 passenger SUV does it in 7.
Not like my truck, which does it in about 17 seconds.
Yeah 4 seconds is poop when compared to my 5 second 5000lb SRT10. J/k
I used regular unleaded gas with 86 octane for a while but noticed the knocking/pinging so I switched to the mid-grade (88 octane) and the knocking/pinging went away.
what the hell is 86 and 88 octane? (dunno)
I have never seen that and if you heard pinging then your knock sensors are hosed or the gas you got is pure sh1t.
OK, so finally after reading all inputs here are my two cents and experiences.
First off the higher the octane the better your engine runs to an extent. The higher the octane the higher the temperature required to detonate the fuel/air mix. Rocker chatter is due to pre-detonation of fuel due to lower octane.
Pre-det is caused by the fuel/air mix detonating before the pistons reach TDC, thus chatter. High alt conditions require less octane rating because of lesser O2, hence slower burning ignition rate.
To state my point, my 9 runs fine on 87 octane; no chatter. So I began experimenting with fuel in Ohio. They offer 93 ocatne. I ran 5 tanks worth through my 9. This being said I have ran 27,000 mile worth of 87 through before testing.
What I have noticed; There is a big diff in response, with 87 when tromping on the accel the vehicle thinks for a sec than wakes up, ripping my head ove the head rest. Having 93 in my tank the vehicle is much more responsive to throttle input.
I cannot believe otherwise that the 9 has some software that compensated for different octane, not that it tastes the gas but that it measures detonation rate.
I've corrected the problem by using the auto-stick to manually shift the car. No more lag, and it shifts when I want.
I'm sure you know it already, but just incase, the "auto-stick" in the CX-9 is still an automatic. There's no clutch. It uses a torque converter. So, it is not "manually" shifting the car.
Big difference between the real "auto-stick" with clutch that rev match on downshift. And now the newer system has dual clutch for even smoother shifting marketed in different names - DSG being one of them used by Audi.
(rofl2)(rofl2)(rofl2)(rofl2)Makes the fart canners think they are gonna take me for a second.
When running at idle, is it possible that an engine will run marginaly more smoothly when using gas with higher octane?
