OP, if you have not already made a decision check out BNR Supercars website. Bryan there has a GT28 CHRA inside the stock K04 housing for bolt-on, plug and play for our engines. The stage 1 uses stock snail and requires no change in turbo inlet pipe and will work just fine on stock ECU tuning. It's the same price as what you mentioned for the GT25. IMHO, GT25 is too small and will end up costing you some horsepower. The GT28 CHRH running inside the stock K04's housing and compressor snail should duplicate stock K04 performance and have the ability to add some more power with tuning.
I thought my K04 was going out and looked seriously at this option as I want to stay very close to stock. Turned out that I just had a very difficult to find boost leak that I finally tracked down and fixed.
