anyone know how to remove the oem roof rack rails?
p5-02
2002 Mazda Protege5
i popped out the caps and unscrewed it but didnt know if rest if clips or not?
and will water leak in if removed?
any help is appricated!!
Check in the how to section for detailed instructions, but basically you have to remove the interior to remove the headliner to remove the bolts holding it in from the bottom. Then you want the filler strips to fill the gaps left from where they used to be. And to prevent leaks in the screw holes.
