Anyone Have A How-to For Gauge Installs?
NYSP33D3
07' Cosmic BLue Mazdaspeed 3
Looking for a detailed HOW TO thread on How To install a Boost gauge, Oil Pressure and Air Fuel. Picture is really what i'm looking for. THANK YOUUUUU
Only a how to foe a boost gauge buddy... Plus I ant see the pics on that thread fir some reason
this will be the BEST help you'll need for the A/F guage. When I did it, I found a thread with this pic in it and this is the exact wire you need to splice your a/f guage into for it to read. Works perfectly, just use those crimp/tap things and your set. I ran the wire through the hole in the firewall where the hood latch goes. Also ran my boost guage tube through there too. Anyways here is the wire tap into (oh yeah and if you're not sure where this is, this is the ECU harness in the engine bay on the left side of the battery when you take off the long skinny cover, there are 2 harnesses and it's the one closest to the front end of the car, 5th wire on the far left side, it's white):
As for installing the boost guage, its really easy, just need to run that boost tube up to where the bypass valve is and there is a hose that goes into the top. you can cut that and put a T in there and connect the bottom of the T to your boost tube that goes to your guage. If you don't want to cut it, then put the T at the end of the stock blakc tube that goes to the top of the valve and then cut your boost guage tubing and put it on the left side of the T going to the top of the valve and the bottom of the T will be the longest part that goes all the way to your guage
