=) ok, its the same thing. so, if i have torque, then that means that i must have power, correct? so, this statement directly contradicts the one you just made. "HP is a rating of how much work is being done. You can have torque and be doing NO work." so if its the same, how can you have torque and not be doing any work? simply put, you cant. in order to get torque, a force must be applied. and if you have a force, then obviously you have to be doing work applying that force. hp is simply how much work can be done(ft/lbs PER MINUTE). torque is the amount of pressure(ft/lbs) created by applying that force around an axis.
