I got it working, sitting at idle it seems to hover around 137F.  So this should work then when I go to do my drain/fill.  I'm guessing I let my car idle till it hits 122, then shut it off and check the level, otherwise the temp will keep rising.
My 2015 hasn't had any other issues knock on wood, so other than geeking out on all the info/data you can see is there any reason to possibly buy forscan lite?
I may still send my bafx back and get the Vgate vLinker FD OBD2 Bluetooth just in case I need better compatibility in the future with FORscan.
