I finally got around to buying some Pocket Wizards. I need to get CS4 since CS3 can't handle the 5D MKII RAW (CR2) files.
But, looking at the difference in exposures in the sky, I don't think you were shooting in manual mode.l
pfft potn is useless. only reason I visit there is to buy used gear off people that overspend on something they have no clue how to use.
If you're shooting in manual then you probably forgot to manually set the white balance. But, looking at the difference in exposures in the sky, I don't think you were shooting in manual mode.l
some pics from last weekend
How dare you! ; )... so im lying? Interesting.
gr...congrats on the upgrade to the PW's were u using the cactus triggers previously?
Also, Lightroom? I have integrated it in a rather unsophisticated way, but the benefits to my workflow and image-to-image consistency are measurable.
No, I was using the Canon ST-E2 but the IR system is limited outdoors on sunny days. The distance limitation doesn't allow me to shoot at 200mm and fire the slaves. I'm still debating on whether to pick up another Alien Bee B800 and a power supply instead of using the Canon 430EX and 580EX. I don't think I'd be able to fit two B800, power supply and 2 light stands in the Miata trunk, though.
Nutari,what's your name on POTN ?
My camera bag takes half the trunk lol
I'd have to stuff my clothing and other items on the front seat. Passenger? Forget about it.
POTN ain't that bad. There's some really good info on there. He got s*** on because he asked a question if he's got what it takes to be pro, and proceeded to post pics that weren't up to par. Then a lot of ppl jumped in with some harsh criticism. And exif data didn't explain some of his pictures either. Go figure...
anyways, GR is right. Those lines should not be happening. Sounds like you have to look at your exposure meter on the camera. Because when you change angles, even if you are standing still, the position of light source changes. So, get a tripod ( if you haven't already), try using M mode again.
Either that or just go into pshop and you have A LOT of blending to do.
