Any interest in an intercooler spray kit?
I'm doing it half for the coolness factor. It will help SOME but it's not going to be awsome....I figuer (sp) with a CAI from Injen, a ram air mod and some kind of sprayer, I'll be doing what ever I can to get the air cool.....short of spending 600+ for a new FMIC.
II-Savy said:
So how's everything emode?
I for one am dieing to see this kit. I think it sounds cool. (no pun intended) :D
I hope it has a nice switch to mount, maybe a momentary(sp) switch.
You will be happy to hear that the switch I have sitting in front of me is a momentary switch, just waiting on emode to get his car back together and we will do the install. My only worry is for those of you with stock airbox setups it doesnt look like there are a lot of mounting options for the resevoir. You may be required to remove the snorkel for this kit to work.
what kind of monentary switch is it?
i tried to mount a "nos" momentary switch to my steering wheel, but it did not work out the way i wanted it to, so now i have a toggle mounted beside the rheostat in the plug.
Not exactly sure what type of switch it is, but its a push button one :D It provides power when the button is pushed. Should work just fine its an automotive grade switch so it wont burn out.
Basically we have canned the idea for an intercooler mister, its just to hard for emode to come up here and work on his car and I have no access to a msp. Good news is I have sourced most of the parts for the do it yourselfers.
First off the resevoir with 12v pump included can be had at autozone for about $25.00. This kit has almost everything you need to set this thing up! It includes the resevoir and pump, along with a momentary switch, cheap nylon hosing, nozzles, and a tee to hook up two nozzles (very cheap nozzles). Part number is #9-400 and once again this is at autozone autoparts.
Secondly I would recommend buying some silicone hosing to use instead of the nylon hose. Or I would also try to use rubber auto hosing, which would be alot cheaper. Can be found at any auto parts store.
Lastly the nozzle, in my view the most important part of the kit. Here is the one I was looking at using: http://www.autospeed.com/shop/category_705/browse.html
But a forum member by the name of unwound was nice enough to point me towards www.rittenhouse.ca.
The parts list:
teejet disc nozzle hss d3 $0.78 424
teejet brass core 25 $0.97 425
nozzle body 1/4"x 1/4" 1321a $1.09 452
strainer w/ check valve 4193a $2.57 454
*specify the 100 mesh size
nozzle cap 1325a $0.69 457
total: $6.10 each
call the 1-800-461-1041 number and do the order over the phone (that is what i did) the cust svc is awesome. the website is very hard to navigate.
This nozzle info is courtesy of unwound, once again thanks alot!
So it looks as though the complete kit would have cost under 50 bux, which is way below my original estimates. I hope someone on here will go ahead and put this kit together and find some good results.
Last thing I just wanted to say good bye and good luck to my good friend jdm sam. I dont know what your problem is but hopefully you will get laid or your male enhancement pills will work or something.
that is very classy to give up an idea like that for us. I know its not rocket science and I'm sure someone else is doing it already, but still very cool of ya. Oh yeah, Go jdm sam haha
Just a question why would you use water?? If you used that at the track they would kick you off.
