I am having issues getting my FD's turbos to operate properly. It is going to 5 psi for a couple seconds then dropping to 0. I thought it was the actuator on the exhaust manifold acting up so I tied the flapper (the one for the secondary turbo, not the wastegate
) open expecting both turbos to just spool in parrallel and it just stays at 0 like that. I am stumped here. I even pulled the lines from teh wastegate actuators with the flapper tied open and it is still sitting at 0. When I got the car, it had bad turbos on it and was boosting around 3 psi then down to 0. Apparently the problem has been there since before I swapped. Any ideas out there?
Joe
Joe
