Any dyno graphs after test pipe install?
VRMS6
2011 Kona Blue Ford Edge Sport
Anyone have any dyno info for a "after" test pipe install? I installed a SU test pipe and SOTP feel is pretty good. Im intrested in seeing concrete info on HP gains with the test pipe. Anyone do a after dyno pull??
Wow, I thought it was only about 10hp...VRMS6, can you describe your results in a little more detail? Better spool, lower rpm spool, responsiveness?
He must mean a DP. There's a dyno somewhere unless it has been taken down. I think it was about 10 hp. I'd like to find it if anyone knows where it is.
correct. full downpipe (three pipes total replaced) is about 30whp.
the test pipe alone is between 10-15.
Got mine installed on Sat....took about an hour with the car up on ramps. Went to Lowe's and got some Grade 8 bolts for the downpipe side. New gasket for the back as well. Car pulls much harder between 3000-6000 rpm, but doesn't sound much louder till you really get on it. I'm very happy with the results.
steve it took you an hour? How hard was it ? Im thinking about getting one but I only have a jack / stands it might be a PITA to get under there with the car so low.
I'm a pretty big guy (6'4" 260 lbs) and I snaked underneath on just ramps in the front. The hardest part for me was getting enough leverage to break the front bolts loose. A 1/2" drive socket or breaker bar can make things much easier. Once you break everything loose, it's not bad at all.
alright doesnt sound too bad then. Looks like ill order one and install my forge bpv while im working on my car. Thx for the info
