any camber issues with Tein S on the MSP?
blackmspstl
Potential Scammer!
03 Mazdaspeed
just like the title says. ANy one who has the Tein S springs on there speed are you having any camber issues front or rear? ANd were you able to get it aligned back to specs with the springs installed?
thanks
I have had mine on for about 6 months and havent had any problems. I the alignment seems to be right. Hope that helps.
anyone knoiw the part number for the springs, most of the fit giudes I find online exclude the mp3, so dies that also disclude the msp?
I got them,and yes there is a issue with front camber.plan on losing a good 5 thousand miles off your tires life.
advice:
geet a camber kit or camber plates.
I would say yes, plan on front tire life to drop a good bit... My tires are wearing on the inside a good bit more now that i'm lowered. camber correction kits, however, are relatively inexpensive, and quite easy to install... if you put your own springs on, you can put a camber kit on. I just put a kit on all four wheels of an 04 civic. took 2 hrs tops. I havent' researched any for our cars yet, because my tires were already shot.
I thought camber could be adjusted on our cars without camber kits?
Can't an allignment fix the camber? We don't drive Honda's ya know.
Camber can be adjusted to an extent. The camber kit will allow you more adjustment.
sickspeed94 said:
BUMP, i'd liek to know as well, plan on picking up a set, if only those am sportlines were linear!!!
the sportlines are progessive? I didn't know that was definite. Do you happen to know the spring rates as well?
wait, i'm going to try to find out about the progressive-ness (whata word) because i always thought them to be linear, i really want them, badly! so maybe thay are linear (but i read elsewhere they were progressive)
sportline owner(s) feel free to chime in (wrc)
