Not a solution (nor the problem, as my CX-9 radio reception is better than any other car I've had for a while), but you can do some diagnostics yourself. If you have the bose/nav setup, turn audio on, press and hold POWER, then press the AUDIO button while holding POWER. That will get you into the "Failure Analysis" system. There are 00-99 codes, most of which aren't active. My apologies, but I have not yet written down what each code does, but I do recall (a) antenna connection check code and (b) an ability to display signal strength on radio stations. Something to hack with for you, you seem to enjoy that
. See related post on Nav touchscreen accuracy adjustments started by OMF as well.
Lexx
