Another Map Clamp :)
Davidb
Well I did the install. I made my own map clamp and installed a boost controller tonight. The whole install was around a hour and a half...it wasn't to bad. I have my map sensor clamped at 3.76v and i'm running 18-19psi...this was done in 4th gear with no stutter. I hit boost cut with the map sensor at 3.92v at 18psi in 4th gear. It was pretty easy...I used a volt meter to test this. I love it :) Thanks for all the great info on here :)
Now I need a wideband...ups needs to hurry up...lol...
