I have a CP-E Catback single exit, resonated with no muffler that rattles like no end on the factory tip that is in the bumper. When i give it some gas it will go away but at different rpms it still rattles and at idle it ALWAYS rattles. I also have an SU TP but I've had this issue prior to installing the TP. I want to keep the factory by all means, so I'm in need of suggesting solutions.
I've already tried moving it around but the hangers always put it right back to the same spot that makes it rattle. I was thinking about securing a trimmed timing belt around the muffler, only because I cannot think of any other rubber that would not melt under the heat of the exhaust tip. But I'm unsure if that would even work.
EDIT: If this is in the wrong section, mods feel free to move it
