Everything looks goods, but what gear shifts are we looking at? 3rd-4th-5th? Because the knock in 4th I believe is a little high @ 2.1 for just having an Intake, but not dangerous enough to blow the motor like say 7.0 or so. I have a SRI, BPV ,and a CBE and I don't even see knock over 0.7 and I'm on 91 octane.
Start datalogging fuel pressure along with the knock retard and see if it drops below 1000psi @ WOT. If it does, that mean your fuel pump is on it way to dying. At idle after the car has warmed up, Fuel Press should be around 420-450 psi
