chuyler1 said:You will only get the 3Ω load if you use both subs. These are 8" subs and they shouldn't take up too much space in your trunk. I don't know what the recommended box size is but a sealed enclosure for a pair of average 8" subwoofers is only about .6 to .8cuft. That's about the size of a box for a single 10" subwoofer.
Brian, your power calculations are wrong...
If an amp puts out 800w at 2Ω and 400 at 4Ω...
watts = voltage^2 / impedence
800 = V^2 / 2
V = 40
W = 40^2 / 3
W = 533
So if the amp was rated properly, your pair of 8" subwoofers would receive 533w from that amp, or 266w each. This is close to what I am sending my 8" Eclipse subs, and they hit pretty damn hard.
Yeah, I was just guessing. I knew it would be less than at 2Ω, but more than 4Ω - I just didn't want to dig out the calculator.
And, that sub he is talking about is a dual 6Ω coil sub. So, if he uses one, he could wire the coils in parallel fopr 3Ω or in series for 12Ω. Also, he said they were 10's not 8's after all...
