Alternator Upgrade
splitvizion
2004 Mazda 3S
Is it possible to upgrade the alternator on the 04 Mazda 3s hatch. If so, what does this imply. I thought the alternator was some how linked into the ECU and that would take some kind of reprogramming. Thanks.
anthony
I know the alternator is regulated by the ECU on the Proteges and I think the same may apply to the Mazda3. If this is true, it basically means you cannot replace the alternator. The only option is to remove your A/C compressor and install a second alternator dedicated to whatever electronics you wish to power with it.
Try searching the forum for "alternator upgrade"
sacrificing the AC is not at all a problem seeing how the AC is horrible to begin with. On top of that I have a fiberglassed HU where the center vents were so now it really takes a long time to cool the car. can you give some kind of brief explanation as to how i can add the other alt. or maybe a site that I can get the info from.
Thanks]
