For some reason im getting alternator noise when im on FM or AM BUT NOT on CD. I have a pioneer premier mp470 cd player . I took the stock radio and stuck it back in and same problem so its not the radio . Im grounded on the stock ground so i tryed a different ground , i ran a 14 gauge wire to a steal beam under the dach and no luck it still does it . Now i noticed something , when i unplug the ground wire the radio still works ? it that normal ? The only thing i did'n try was to run a fat ass wire straigth to the battery . Im thinking the radio is grounding from the antenna but from where ?? The antenna wire seams fine .
I have no amps or aftermarket speakers . So im sorta out of ideas to try . Do i need an antenna filter or a power filter or something ?
Please help me ! thx
