enry
Administrator
I have a 2003 MSP, if I idle at warm and headlights and AC fan on, 15 amps are pulled FROM the battery, which means, eventually, it will die on its own when the battery is discharged.
I have to stay over 2000RPM for the alternator to generate the required current. However, my idle at warm is 500RPM whether lamps+AC fan are off or on.
Sometimes, when I am at 3000RPM and driving, if I go to neutral and let go of the gas, the car will stall.
Here's what I've checked so far:
ALTERNATOR OUTPUT CURRENT
40amps if over 2000RPM.
BATTERY CHARGING CURRENT
+10 over 2000RPM with lights+ac fan on
-20 at 500RPM (warm idle) with lights+ac fan on
BATTERY
The battery is good, no dried up elements, it seems it can hold a charge.
When charged, 12VDC with engine off. With engine on, 14VDC when over 2000RPM, decreases rapidly if idling and with accessories on.
BELT
The belt that feeds the alternator feeds the AC and vacuum pump, and both AC, power steering and power brakes work fine. No horrible belt slipping noises.
SPARK PLUGS
clean and properly gapped
This seems to me not normal behavior. Is it possible that the alternator is putting out insufficient current
Or, should the PCM be smart enough to compensate for current draw (or battery voltage < 14V) and increase the idle RPM automatically ?
The service manual chapter on the generator is BS, and only says that the alternator should put out more than 0 Amps. Wow, thanks, I had no idea.
The following issues in the symptom troubleshooting section of the service manual look interesting:
NO.5 ENGINE STALLS-AFTER START/AT IDLE
[FS] . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0103B17
NO.10 LOW IDLE/STALLS DURING
DECELERATION [FS]. . . . . . . . . . . . . . 0103B26
NO.11 ENGINE STALLS/QUITS, ENGINE RUNS
ROUGH, MISSES, BUCK/JERK, HESITATION/
STUMBLE, SURGES [FS]. . . . . . . . . . . 0103B28
Should I focus on one in particular?
BATTERY
BELT
SPARK PLUGS
