I am selling an old school Alpine 4-channel amp. It is an MRP-F200, made when Alpine used to make bulletproof amps.
Here are the specs:
* 40 watts RMS x 4 at 4 ohms
* 50 watts RMS x 4 at 2 ohms
* 100 watts RMS x 2 bridged output
* 2-, 3-, or 4-channel output
* Tri-way capable (Tri-Way crossover required)
* requires 10-gauge power and ground leads wiring and hardware not included with amplifier
* Bass Engine features:
o selectable 80 Hz high-pass/low-pass crossover at 80 Hz, 18 dB/octave (2 separate crossovers, one for channels 1 & 2, another for channels 3 & 4)
o tuned Bass EQ (8 dB bass boost at 50 Hz)
* preamp outputs
* MOSFET power supply
* STAR Topology (minimizes internal noise and prevents ground interference)
* speaker- and preamp-level inputs
* gold-plated screw terminals
* blue power LED
* 11-13/16"W x 2-5/16"H x 10"D
Works great and comes with a small ground cable too. $55 shipped!
Here are the specs:
* preamp outputs
* blue power LED
