All warnging lights displaying
justgeorge
2010 CX-7
Hi all, first post. Was driving our 2010 CX-7 Grand Touring and all the warning lights were on - BSM light was flashing, the Traction control warning light on, emergency brake light on, oil light on, and the turn signals work but you don't hear the "click click click". Turning it off and back on didn't do anything.
Dealer is closed on Saturdays so I disconnected the battery cable for a bit. Now the BSM light, oil light, and emergency brake lights went off but the traction control warning light and the "TCS OFF" light are both still on.
It's gotta be computer related I would think, any other reset to do other than disconnecting the battery?
Also we've had intermittent problems with the key fob not being recognized and we have to use the hard key.
Thanks
yeah, the battery possible. or you may have some other possible electrical issue. is everything still working correctly?
I have the same year/model as you, had the exact same symptoms (including the silent turn signals), and as you have no doubt concluded, the car runs fine, and there is really nothing wrong except for the lights on the dash. Even without disconnecting the battery, the problem does go away after a while, but will also come back. After my 2nd report of the problem, the dealer replaced the General Electronic Module (Part # EH45-67-560E) back in June, and the warning lights issue has not returned. We still have an intermittent problem with the key fob, but once you open the door with the hard key, it works fine. We also have an intermittent problem with HomeLink forgetting the codes. Dealer has ordered a new rear-view mirror (apparently, HomeLink is completely contained in the mirror).
BTW, if you disonnect the battery, get a jump, or pull the Room fuse, the TCS light will stay on for a little while. This is normal.
Has anyone had the TCS light pop on and stay on without the above circumstances (battery disconnect, jump, etc.)?? Mine recently popped on and is not going off. Any ideas? Btw - it's an '06 Speed 6.
