It won't take care of the issue.If it leaked, you would not hit fuel cut, you would just feel a dip in power. Besides, I thought you had a boost gauge?
As you know my car has been stuttering with the forge bpv on. i put the stocker back on and my problems all went away.
IF YOU VALVE ROTATES AROUND THE FLANGE, IT IS LEAKING!!!!
i called forge and he confirmed that it should not be rotating at all.
this is an easy fix. Take the valve off, turn it upside down, you will c a snap ring with two depressions in it. insert needle nose pliers into the depressions and rotate the ring clockwise as hard as you can untill the flange no longer budges.
BTW i called 3 poeple with this vavle....all of theirs were leaking, chances are yours is 2.
you welcome(headbang)
not the top, the whole valve itself moves. You know the thing u screw onto your intercooler, thats the flange. The cylinder looking thing wtih the two hoses attached to it, one on top one bigger on out the side. Thats the valve that moves independent of the flange. Try turning it, and use some muscle
valve flutter is nothing to worry about. comp. surge is bad though. most valves that are stiffer than stock will give a flutter with a low boost vent.
