As you know my car has been stuttering with the forge bpv on. i put the stocker back on and my problems all went away.
IF YOU VALVE ROTATES AROUND THE FLANGE, IT IS LEAKING!!!!
i called forge and he confirmed that it should not be rotating at all.
this is an easy fix. Take the valve off, turn it upside down, you will c a snap ring with two depressions in it. insert needle nose pliers into the depressions and rotate the ring clockwise as hard as you can untill the flange no longer budges.
BTW i called 3 poeple with this vavle....all of theirs were leaking, chances are yours is 2.
you welcome(headbang)
