- 2023 CX-5 Premium; 2018 Mazda 3 GT hatch
The price you pay for being a brilliant mechanical engineer Chris.See what I deal with.
So why did you modify the lateral links when everyone else in the known universe is selling adjustable camber arms for this purpose?These are not the camber arms. These are at the bottom and they are called lateral links. Toe adjusters are at the rear of the wheel and these are at the front of the wheel.
The camber arm, is at the top of the wheel.
Amen! Although he modified aftermarket, not OEM parts, the same holds true.
JBR has camber arms? I didn't know that.
I have modified the original lateral links, adding adjusters to them. It cost me half, then those camber arms.
The arms are OEM. What I have put in there, are much stronger then the tube itself.
Believe me, I turn hard as hell and I did not have any issues yet. I push the gas, after I have reached half of the corner, not braking. I have also 20" wheels.
I have drove the car for well over a year now, since I have made the modification and no issues yet.
(cryhard) sounds like you need to work on your suspension lol time to get rid of those corksport and grab a fsbI take really hard turns, once I have even hit the sidewalk.
It appears that Megan camber bars are exactly the same as Hardrace, are more widely sold and at lower prices.If your getting rear camber get these Hardrace. Much better construction (forged and milled, vs mandrel bent and welded) and have already read about problems with the exposed spherical joint on the jbr. http://www.buyhardrace.com/product/hardrace-rear-camber-arms-harden-rubber-12-14-cx-5_324.html
So Megan (and presumably Hardrace) offer the camber arms and toe control arms as a set. If I'm only lowered 1.5" (actually 1.75" in the rear w/H&R), am I going to be able to get adequate rear toe with the OE adjusters if I only use the camber arms to regain proper camber settings? 2WD Touring on stock 17s. No other mods.Yes, Megan Racing imports directly from Hardrace. I think they are out of California. But they don't offer everything that Hardrace does. In this case, the Megan part may be cheaper, but buyhardrace.com is just a vendor (velocity speedshop in florida), so price may be cheaper elsewhere.
