alarm help needed
tweety2300
2001 mazda protege mp3
Ok so my alarm is completley crap. The box doesn't seem to be the original because there is no screw for the sensitivity setting the shock sensor also didn't have a wire going into and there were no disconnected wires. But when she got to work this morning the security light started going off and clicking as if the alarm was actually going off but the horn wasn't honking or anything like that. My questions are is this the reason it sometimes doesn't start unless u jiggle the box. Can any alarm for a protege out of a junkyard work temporarily? Has anybody had this issue before? And is there a way to jerry rig it so that it will start untill I get an alarm box so that it will start. I can not get it to start without the box hooked up unless I push start it which is weird because I thought you could? And is there any other problem that it could be?thanks in advance
