Airbag Light Flashes After Prolonged Exposure to Cold
So update. It has nothing to do with the connectors. This has something to do with the crash/pressure sensor in the drivers door. Either the sensor is bad, or there is a broken wire from the SRS unit to the door sensor ( really hoping it’s the sensor as tracing those wires down would be a lot of work ). I have a Module in order and will let you know what I find out 👍
After taking it to the dealer, they couldn’t tell me either. It was actually a broken wire in the drivers door boot I found . I was really surprised. Replaced the wire and it’s good to go. Mine was intermittent as well for sometime so must have still had a small connection. Those wires are a twisted pair and must have had too much tension from the factory.
