Aftermarket spring vs. coilover ride differences
This is with CS springs.
attachment.php
^ Looks great! Cant wait to do some tuning to it. Recently just got the KE. Wish more options for parts though. Is like a forgotten child
Has anyone tried the AutoExe springs for the CX-5?
tibimakai,
Have you adjusted your headlights? I imagine they're pointing down quite a bit. Mine did a bit with the H&R springs. I tried adjusting the headlights with the screw on the back but it didn't seem to help much. Guess if there was a way to adjust that headlight lever on the rear suspension...
There's an adjuster on the rear suspension (2016 at least).. if the back end drops due to heavy load, the headlights aim downward to compensate. With lowering, it doesn't know the front is lowered too so the headlights point a bit downward; mine did a little with the H&Rs. Just enough to be a little bit bothersome on a dark highway going 70-80mph. There's a thread on it. Here's pick of the auto-adjuster. Was hoping someone found a way to adjust (and how much)
http://tapatalk.imageshack.com/v2/15/03/19/f28f6957b70e3fecfbd4552e0a40fcd3.jpg
