Hey guys,
After recieving the FTC, I am logging and changing my settings slowly, I am very confused as to how my AFR in open loop is so jumpy???
I realize it will fluctuate whenever it is in closed loop..... but It is jumping around a whole lot...the largest jump in this graph is from 12.25 to 10.71
<a href="http://s1337.photobucket.com/user/f1yen/media/jumpy_afr_zpse7ee5582.jpg.html" target="_blank"><img src="http://i1337.photobucket.com/albums/o662/f1yen/jumpy_afr_zpse7ee5582.jpg" border="0" alt="JumpyWOT_AFR photo jumpy_afr_zpse7ee5582.jpg"/></a>
I also before commented about my AFR seeming to swing alot more than I seemed to remember... logging freeway speed, I logged the swinging of 15.6 to 13.3....This being the largest swinging I have seen. a video of freeway: http://www.youtube.com/watch?v=YFCvi5RgMPo
I feel like the graph should be less choppy...... I definitely dont want to tune around a problem..... Does anyone else have logs that they can post?
In open loop, the problem could be fuel related (faulty/slow injector? or fuel pump? of which I do not know how to test those )
Boost leak done yesterday, and absolutely no leaks except for some leaking into the cylinders (open valve?)
Right now I am not using the SSFTC overboost function, because When I use it, my STFT's increase to +25 in about 3 seconds, and I am not a fan of chasing my tail after trims. I have also replaced my MAF within the last 3 months, and a new front denso o2 sensor within this last month. No audible/visible exhaust leaks, I am heistant to seafoam the engine (for exhaust leak), because I heard they break o2 sensors, and I don't recall how expensive the MTX-l wideband one is....
Hopefully one of you can either share with me/post on here logs or screenshots of logs?
Any help would be appreciated
