AFR gauge question
djdanny5000
Contributor
2007 Mazdaspeed 6 GT Retired: 2002 Protege 5
I have a prosport AFR gauge but it's a narrow band not a wideband gauge and i'm wondering which wire to splice into the stock o2 sensor? Also i'm wondering if a narrow band afr gauge will work because i've read a few times that the speed 6 comes with stock wideband o2 sensors
The narrow band AFR gauge is essentially useless on a Speed6. The front O2 is a wide-band and you need a Dashhawk or similar OBD2/CAN device to monitor the AFR from it through the ECU. Your procrap won't work on it. The rear O2 is a narrow-band and you can splice into it and your procrap will work to indicate lean or rich from 14.7, but the AFR measured there is not really used for anything.
I don't have the wire colors right now, but I can get them from my wiring diagram later if you really want the right wire to cut and splice into....
I take it your investment portfolio doesn't include an shares of PROC, lol.
So that explains alot. thanks for the info cause right now i have it pluged into the front o2 sensor and it's not working which makes sense if it's a wideband sensor. I think i'm just gonna end up getting a wideband gauge
Why? You dont need a wideband...the car already has one! Get the Dashawk like Forza mentioned. Its cheaper than a wideband and does more.
Well i have the cobb AP but i rather use that to monitor KR and have gauges for my AFR and boost and eventually oil pressure
