I want to turn up the boost a little on my car soon (next month or so) nothing too serious, just around 8-9 psi. Mods that I will have are ssafc, silicone hot pipe, silicone cold pipe, open filter, and hopefully an upgraded bypass valve. I am still running the stock map on the ssafc, will i need to run a different map to turn up the boost safely to 8-9 psi? I do not have an A/F meter as of yet so I don't really know what the afrs are like now and how they should look. I don't plan on putting it anything above 9 anytime soon. If there is a safe map that is for 8-9psi for the mods that i have that would be great, but all im seeing is 440 injectors and fmic mods with 10 psi it seems. :/ any insight or help would be greatly appreciated. If this is in the wrong category, please move it. Thanks for reading.
