i do not have that problem. the problem i have is the car not going into open loop when it supposed to.
i was reading up on a old thread and DSMCONVERT clams since our cars have heated o2 sensors, it takes the output b mode to work fully when the o2 sensor is fully warmed up.
the problem i have is that my o2 sensor takes about 10 mintues to warm up in my car. so for the first 10 mintues of the drive, when i go into boost, it is still in stoichometric procedures. thats a problem for me, because the first 10 mintues is critical. if someone drives my car then floors it without letting the
o2 sensor warm up, that could lead to some bad news, and more spending at protege garage, lol.
DSMCONVERT claims that in their testings, that never happend before because their test car was new. they claim, after about 20,000 miles, the o2 sensor builds up too much carbon for the sensor to get fully warmed up as it should. that is deff. my problem, because this would happen to me in my NA set up as well, with a completly different ecu.
he also said instead of buying a whole new o2 sensor, people are able to take some brake cleaner to it and clean off the carbon, and that would make the
o2 sensor work as it should. i also talked to one of the reps from protege garage and he advise me to clean off the carbon build up as well instead of me buying a whole new sensor.
however, i personally do not think this is the problem for you Wingman21, i was just trying to let you and everyone else if anyone had my problem then this is the way to fix it.
when you installed the unit, did you forget to disconnect the battery? sometimes when the ecu does not fully reset, the afc can mess some settings up from the ecu permantly. the ecu is relying on the splitsecond afc because that is the way the afc was designed to work on mazda's ecu.
you should probably think about getting your ecu reflashed incase this happend to you. there also could be a problem with your ecu that is frying the air fuel controller. it is something to think about and maybe look into. the best of luck.
