GhostMercury
- MazdaSpeed 3 08.5
I like the look of a 17" with a beefy tire, but I am trying to figure out what is the best tire size to run. The car I most like is tigermacks
I am planing on running a set of Rota SVN
They are 17x7.5 with a 45 offset
I have been doing alot of research on tire sizes, using a tire calculator, and comparing them to sizes I have seen on other cars, as well as comparing them to stock tire sizes.
This graphs is comparing 225/50/17 to stock tire size- Stock is Tire1
235/50/17
Now Tigermacks car is running 255/40/17, so camparing sidewall heights to his
255/40/17 - 4.02
Stock - 3.81
225/50/17 - 4.43
235/50/17 - 4.63
or
235/45/17 - 4.16 if I want to run a Nitto Invo tire.
So my question is...what will fit? If I have to roll the rear fenders then fine, but if it will fit without even better. I am running YellowSpeed coilovers, so I can adjust height and front camber. Soon rear camber as well when I get some adjustable rear camber plates.
And do you think I will notice alot of sidewall squish or roll while running BFG G-Force KDW 2 at this size?
235/50/17
255/40/17 - 4.02
Stock - 3.81
225/50/17 - 4.43
235/50/17 - 4.63
or
