Adjusting the clutch pedal (works great)
seanw
2006 Titanium Gray MS6
To everyone who still hasn't gotten used to the high engagement point of the clutch, it is easy to adjust. Remember, this is clutch, an important part of your car and expensive to repair if you screw it up. So make sure you scope out the situation completely and all that before you do it. Search the net for complete and excellent description of the process by Super Car Tastes - Skoda Budget, etc. Anyway, after marking the original position, I shortened the plunger rod by three full turns. Then I adjusted the pedal stop so that there was a little play before I could feel the plunger rod engage the plunger. This puts the pedal just a little higher than the brake instead of way higher.
I did this based on the advice of another poster who had suggested a range of 2.5 to 4 full turns, so you have to adjust it to suit yourself. The more you shorten the rod, the lower the engagement point. The pedal stop adjusts the pedal height and the amount of play before the plunger rod engages the plunger. Much better, I mean normal. But I think I may back it off to 2.5 since 3 seems to put it a little too low.
When you've gotten used to clutches with a lower engagement point over the years, it's really hard to retrain your muscles and avoid giving it too much or too little gas. If they had come from the factory adjusted for a lower engagement point, I think no one would have complained about the clutch and they would have sold more. I really don't get it.
hey does anyone have a link on this, I've been searching for a little bit, going to continue searching but Iif anyone has the link I might want to try it out. Thanks...
Author: Super Car Tastes - Skoda Budget
Okay, took me a while but I got it together. As mentioned earlier I did the clutch adjustment today. Its a huge improvement, and I made sure there wouldnt be any issues with insufficient disengagement or re-engagement of the clutch. Also, I formulated a theory as to whats causing the problems.
Make sure you fully read the instructions and study the pictures and diagrams to ensure you fully understand the process before starting.
Please note: I put these directions together based on my personal experiences. I am not a mechanic and do not have any professional certification. If you try this, you do so at your own risk and release me from any liability, damage, injury, etc. You assume all responsibility!
Heres the How To, with some explanations and diagrams to avoid mis-adjusting the clutch:
Tools needed:
12mm crescent (open ended) wrench
Light source (I used a head mounted light to put light where I was looking and keep both hands free)
10mm crescent wrench for clutch cylinder actuator rod (not really needed and actually very difficult to use, but just in case you want to try)
Permanent marker such as Sharpie or Staedtler
Steps:
1. Turn off the engine!! Dont do this while the car is running!! Obvious but you never know.
2. Move the drivers seat all the way back to give you room to work.
3. Slide in head first on your back and get under the dashboard. Identify the clutch pedal arm stop bolt. It will look like this:
(IMG:http://i39.photobucket.com/albums/e158/DWBiker/UpperStopadjustment.jpg)
4. Mark the bolt with a dot or line at one side with the Sharpie. This will give you a reference point. When turning the bolt keep track of how many turns you did and you can easily reverse it back to original.
5. Identify the clutch cylinder piston actuator rod. Its further up the clutch arm from the stop bolt and looks like this:
(IMG:http://i39.photobucket.com/albums/e158/DWBiker/Clutchcylinderactuationrodadjust-1.jpg)
6. Mark one of the flats on the actuator rod as well. Its tight in there so do what you can. As long as you can clearly identify your mark youll be able to keep track of its position. However, its not really critical to keep track of it as youll see later on.
7. While youre down there, press the clutch pedal slightly while watching the actuator rod and piston (see diagram above). You should be able to feel and see some free play before the actuator rod actually starts to engage the piston. This is normal and necessary, as this means the clutch cylinder piston is fully released, ensuring the clutch is fully engaged.
8. If you want to keep the amount of free play the same, pay attention to how much it is now, so that you can duplicate it later after making the adjustments.
9. Use the 12mm wrench to loosen off both lock nuts (theyre both 12mm)
10. Push on the clutch pedal to take tension off the stop bolt and you should be able to turn it in. Turn it in (CW) about 2 full turns to start. My final adjustment was about 2.5 turns in. Refer back to the pic of the upper stop bolt.
11. Tighten up the lock nut to set the position of the bolt.
12. Now, check the position of the clutch cylinder actuation rod. You should find that its depressing the clutch cylinder piston in partly now. Back off the actuation rod by turning it (screw in towards the pedal). Its still CW rotation if youre looking at it from the firewall, but youll be upside down looking up from the floor, so experiment.
(IMG:http://i39.photobucket.com/albums/e158/DWBiker/Clutchcylinderactuationrodadjustmen.jpg)
13. Adjust the rod until its clear off the piston, and there is a slight bit of freeplay (I set mine up with just a pubic hair of play).
14. Tighten up the locknut with the 12mm wrench. The rod will rotate a bit CW due to friction of the threads but this just increases the free play so its okay. Compensate for it by not rotating the actuator rod quite as far as you actually wanted to, so that when you tighten the lock nut it will rotate into the desired position.
15. Eyeball your handiwork, make sure the locknuts are tight, then take it for a drive. This is important test and adjust, test and adjust. I went through 4 adjustment cycles until I was satisfied the clutch was disengaging and engaging properly while giving the best action. I was learning as I was going so it may only take you 2 or 3 cycles.
16. To test the adjustment. Stop on level ground and fully depress the clutch while in gear. Release the brake and see if there is any sense of the car creeping forward. If so, youve adjusted the pedal too far in, so that its not pushing the cylinder piston in far enough to fully disengage the clutch. This is not good, and youll know because when you change gears youll grind the syncros. Im not sure this is actually possible with the amount of adjustment available, and I didnt experience it myself because I advanced it cautiously, but youve been warned! If this happens, back out that stop bolt a bit!!
17. You shouldnt have any problems with making sure the clutch is fully engaged if you make sure there is some free play between the actuator rod and the piston. Unfortunately there is no easy test for this, except for maybe clutch slippage under hard acceleration or going uphill. More probably the mis-adjustment will be minor and result in premature failure of the throw out bearing, but you don't want to find out! Again take this as a big warning!
18. Repeat the above steps until youre satisfied with the feel of the clutch, while ensuring that it fully engages and disengages.
One more time: Make sure you adjust the actuator rod so that there is a bit of free play before engaging the piston to ensure the clutch fully engages!!
Heres a diagram of the parts in rough relation to each other:
(IMG:http://i39.photobucket.com/albums/e158/DWBiker/Clutchadjustmentdiagram.jpg)
Note that the actuator rod is above the stop bolt and only connected to the pedal arm (not below and connected to the piston, as shown in a previous diagram note: it was a valuable diagram and inspired me to do this, so even if it wasnt quite correct it was still appreciated). BTW, I noticed that I put the fixing point for the spring to the car frame in the wrong spot to try to illustrate the possible spring action. Move it to the left of the pedal arm instead of to the right. Now, try visualizing what the body of the spring will do when the top of the pedal arm moves to the left. The body of the spring will "shift", introducing non-linearities.
Now, to my theory and possible clues to identify differences in clutches. Look at this following picture.
(IMG:http://i39.photobucket.com/albums/e158/DWBiker/Clutchpedalspringandpivot.jpg)
Ive identified the big coil spring that is used to return the clutch pedal. Its mounted to the top of the arm. The arm pivots below where the spring mounts (see diagram above). Note my spring has white paint on it. Painting springs is a standard way of identifying springs of different strengths.
I believe, from looking at the system, that the big coil spring plays a major role in the spring rate we feel at the clutch pedal. Its an easy part to change during assembly and its possible Mazda did a running production change due to negative feedback.
It would be interesting to get everybody to take a look up at their spring to see what color it is. If there are different colors, then it means that different rates are being used, accounting for the differing experiences. After this has been posted for a while maybe Ill start a survey to see what color spring everybody has.
Now, heres my analysis and hypothesis of why the clutch feels the way it did (but not anymore on my car):
After looking at the spring/pedal arm/pivot and pushing on the pedal with my hand while watching the coil spring, I came to the conclusion that due to the way the whole system of spring, spring fixing points on frame and pedal arm interacts, part of the motion is non-linear. This is due to the fact that the body of the spring will actually shift as the clutch arm moves and tries to wind it up. If there was a rod through the body of the spring this would not happen and the spring would be linear and act purely as a torsion spring, but the shifting of the body introduces a hump in the spring tension, making it non-linear in a portion of the clutch pedals travel.
I put together three diagrams plotting spring tension vs clutch travel. This is just my guess and is based solely on conjecture. The spring rate curve is pure fabricaton based on my guess at what the spring rate might look like, but I hope it serves to convey what Im talking about.
The first diagram shows what the stock settings look like. Note that the clutch engagement range is smack dab in the non-linear region of the curve, just where it ramps up quickly and then tapers off just as quickly.
(IMG:http://i39.photobucket.com/albums/e158/DWBiker/LessthanOptimalDiagram.jpg)
The second diagrams show what it looks like after doing the adjustments described in the steps above. Note that by moving the pedal arm closer to the firewall its pushed the spring into the more linear region of its curve, and then readjusting the actuator rod to compensate moves the whole engagement range into the more linear part of the curve.
(IMG:http://i39.photobucket.com/albums/e158/DWBiker/OptimalDiagram.jpg)
The third diagram is the one you must AVOID doing, where the stop bolt is moved in but the actuator rod has not been backed off to compensate. Youve effectively and permanently set the clutch up as if you were riding it, or in other words, resting your foot on the pedal so that its partially depressing the pedal resulting in reduced clamping force on the clutch disc. DO NOT DO THIS!!
(IMG:http://i39.photobucket.com/albums/e158/DWBiker/DisatrousAdjustment.jpg)
Whew, I hope this helps. This took me a while to put together, so apologies for any typos, etc, etc. Again, Im posting this for informational purposes only, and do not make any claims as to how this may work for you. You accept all responsibility for whatever happens if you try this out.
(drive2)
Ok I did this this morning. Huge improvement. So much easier to drive smoothly. I ended up about 3 turns out and left about 1/8-3/16 freeplay....which put the clutch lever about 1/4" higher than the brake pedal.
The engagement is completely different. It's not at the point where there is the most spring tension anymore, it's now below that. So you slip out of the friction zone and then the spring tension increases, in fact After you adjust the clutch pedals up travel, you can barely feel that spring increase.
I was about at the end of the tarvel for the clutch pedal depression switch that will switch off the cruise control. You can only press the clutch down about 1/4-3/8" before the cruise control will shut off.
Very happy with the change. Thanks for the link..
I did this this morning as well and it definitely is easier to drive. I did 2.5 turns. Does anyone notice that you seem to get to 3000 RPMs a lot quicker. Can this have any negative effect on the car? I know the clutch pedal went in with this adjustment so I'm guessing thats what did it.
the pedal adjustment will have no negative affects, as long as you have a little free play at the top, and it's shifting smoothy.
There is also no way it can affect your speed:rpm.
Allright, I finally printed the .PDF and am planning on doing. Do you really have to have the caving head-lamp???
Also, I understand this is mostly a feel and engagement adjustment, but what are the chances of it improving my shift from 1st to 2nd, that feels like a syncro or tranny fluid issue?? Anyone else considering some RED LINE eventually?? I'll be back after attempting to adjust this beast. I'm pretty mechanical but also rather large.. I hope I don't really need that caving-light.??
My lil' RED BULL is doing great otherwise with a whoping 650 miles on it.
BTW my mileage has really plummented. My 1st tank was like 23 then 2 @ 20-21, and today on a fill up from empty I got 17.33.. Damn that is almost as bad as my monster 5.4 FORD truck I traded.. This all with mixed driving 70% city and murphy's 93 octane.. Thanks for all the advice.. (ughdance)
(thinkbeer (thinkbeer (thinkbeer (lick) (band2) (boobs2) (butthump) (boobs2)
there's about a 100% chance it'll improve your 1-2 shift. it makes everything involving shifting feel better.
Your right 1 -2 shift is much better. I did 2.2 turns in. May do a little more as my clutch pedal is still 1/4 inch higher than the brake pedal. Are you guys even with the brake pedal after adjustment???
Also has anyone else experienced a MPG drop like I have (see earlier post)?? Hopefully nothing major is going on?? I love my car but there seems to be way too much :bs: for a new car. I am pretty sure it is not the gas as it has all been 93 octane from the same station. Thanks - (drive)
For the sake of it, if somewhere down the road I upgraded from the P5 I have now to the Speed 6, how much of a difference in clutch uptake would there be and how much would you recommend adjusting the clutch pedal(if necessary)?
Would love the link...
Hey all,
Newbie here! Just got an '06 Mazda 6 GT I4. ( couldn't go V6 or I'd lose my license!) But I hate the clutch travel. Can someone PM me the link please?
Thanks a heap...I really like this forum.
(Anyone else in Toronto, Canada?)
Opie
The post has been copied and pasted as it should have been in the first place...It's not hard to copy and past guys...Thanks.
It's not hard to allow links to other sites either....
Uh, fellas, I wouldn't do this... Unless you check the movement of the slave solenoid and can verify that it moves exactly the same amount as before, I would be very conservative with how much you shorten the plunger. If you shorten it too much, it will put the clutch into a place where its not moving enough to completely disengage the clutch, and the clutch will wear out VERY quickly. It will only feel disengaged, and it will be just enough to allow shifting, but it will actually be glazing the clutch.
Beat me to it. Also, if cruise control is in sync with the clutch pedal in the 6, (personally I'm not sure) adjusting it can really tweak it and you'll wonder where the hell your CC went.
Just a heads up, just in case.
-B
I have a 2003.5 protege speed. It grinds when I try to put it in reverse. I need to adjust the clutch pedal out cuz I don't think it's disengaging all the way and that's why reverse would grind when I try to shift. The tranny would still be spinning. Would this help?
New Threads
