Just to clarify even further; The maximum rate the Bilstein PSS kit can handle without a revalving is 350#front and 250# rear. It will cost you $220 for the front pair and $130 for the rear pair plus 2 way shipping and you can have them revalved by Bilstein to match YOUR intended spring rate. Just give them the weight of the car(or corner weight sheet), payload size (average including passenger weight( if you want them optimized for Autocross just include the driver weight)) what spring rate you intend to run, and give them an idea on how you plan to use the car, and what your priorities are (ultimate grip no sacrifices, daily driver occasional track us etc). Turn around time is around 4 weeks so best time to do it is right after you put the winter setup on.
